Preprints, Working Papers, ...
Lock-in Problem for Parallel Rotor-router Walks
Abstract : The rotor-router model, also called the Propp machine, was introduced as a deterministic alternative to the random walk. In this model, a group of identical tokens are initially placed at nodes of the graph. Each node maintains a cyclic ordering of the outgoing arcs, and during consecutive turns the tokens are propagated along arcs chosen according to this ordering in round-robin fashion. The behavior of the model is fully deterministic. Yanovski et al.(2003) proved that a single rotor-router walk on any graph with m edges and diameter $D$ stabilizes to a traversal of an Eulerian circuit on the set of all 2m directed arcs on the edge set of the graph, and that such periodic behaviour of the system is achieved after an initial transient phase of at most 2mD steps. The case of multiple parallel rotor-routers was studied experimentally, leading Yanovski et al. to the conjecture that a system of $k > 1$ parallel walks also stabilizes with a period of length at most $2m$ steps. In this work we disprove this conjecture, showing that the period of parallel rotor-router walks can in fact, be superpolynomial in the size of graph. On the positive side, we provide a characterization of the periodic behavior of parallel router walks, in terms of a structural property of stable states called a subcycle decomposition. This property provides us the tools to efficiently detect whether a given system configuration corresponds to the transient or to the limit behavior of the system. Moreover, we provide polynomial upper bounds of $O(m^4 D^2 + mD \log k)$ and $O(m^5 k^2)$ on the number of steps it takes for the system to stabilize. Thus, we are able to predict any future behavior of the system using an algorithm that takes polynomial time and space. In addition, we show that there exists a separation between the stabilization time of the single-walk and multiple-walk rotor-router systems, and that for some graphs the latter can be asymptotically larger even for the case of $k = 2$ walks.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01021930
Contributor : Przemyslaw Uznanski Connect in order to contact the contributor
Submitted on : Wednesday, May 27, 2015 - 9:58:08 PM
Last modification on : Friday, January 21, 2022 - 3:15:02 AM
Long-term archiving on: : Tuesday, September 15, 2015 - 7:17:46 AM
rr-arxiv.pdf
Identifiers
  • HAL Id : hal-01021930, version 3
  • ARXIV : 1407.3200
Citation
Jérémie Chalopin, Shantanu Das, Pawel Gawrychowski, Adrian Kosowski, Arnaud Labourel, et al.. Lock-in Problem for Parallel Rotor-router Walks. 2015. ⟨hal-01021930v3⟩
Share
Metrics
Les métriques sont temporairement indisponibles
