Next generation structural health monitoring and its integration into aircraft design, International Journal of Systems Science, vol.31, issue.11, pp.1333-1349, 2000. ,
DOI : 10.1080/00207720050197730
Active health monitoring of an aircraft wing with embedded piezoelectric sensor/actuator network: I. Defect detection, localization and growth monitoring, Smart Materials and Structures Pitch-catch active sensing methods in Structural Health Monitoring, Structural Health Monitoring Minimum Variance Ultrasonic Imaging Applied to an In Situ Sparse Guided Wave Array, IEEE Trans UFFC Insight, vol.161016, issue.43, pp.1208-1217, 2001. ,
A methodology for structural health monitoring with diffuse ultrasonic waves in the presence of temperature variations, Ultrasonics, vol.43, issue.9, pp.717-731, 2005. ,
DOI : 10.1016/j.ultras.2005.05.001
Evaluation of the damage detection capability of a sparse-array guided-wave SHM system applied to a complex structure under varying thermal conditions, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.56, issue.12, pp.2666-2678, 1963. ,
DOI : 10.1109/TUFFC.2009.1357
Properties of Generalized Sequential Probability Ratio Tests, The Annals of Statistics, vol.4, issue.2, pp.237-251, 1976. ,
DOI : 10.1214/aos/1176343404
Optimum Character of the Sequential Probability Ratio Test, The Annals of Mathematical Statistics, vol.19, issue.3, pp.326-339, 1948. ,
DOI : 10.1214/aoms/1177730197
The reflection of the fundamental torsional guided wave from multiple circular holes in pipes, NDT & E International, vol.44, issue.7, pp.553-562, 2011. ,
DOI : 10.1016/j.ndteint.2011.05.010
