Conference papers
Damage Detection and Localisation Using Mode-Based Method and Perturbation Theory
Abstract : In this paper, the detection and the localization of a local perturbation are assessed by analysing the frequency changes only (fundamental mode and overtones). After describing the method used herein applied to the bending beam and based on the perturbation theory, experimental application to a 1D plexiglas beam is shown using frequency and modal analysis technique. The damage is considered as a local perturbation of Young's modulus. Finally, the localisation of damage is done using classical modal-based methods and perturbation theory. The frequency values are caught by the Random Decrement Technique applied to the time history vibrations for one sensor at the free extremity of the beam. Detection and localization are successful, even for small and transientchanges of the structure properties.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01022017
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Thursday, July 10, 2014 - 3:36:56 PM
Last modification on : Saturday, January 15, 2022 - 3:53:13 AM
Long-term archiving on: : Friday, October 10, 2014 - 10:46:54 AM
File
0336.pdf
Identifiers
  • HAL Id : hal-01022017, version 1
Citation
Alaa Hamze, Philippe Gueguen, Philippe Roux, Laurent Baillet. Damage Detection and Localisation Using Mode-Based Method and Perturbation Theory. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022017⟩
Share
Metrics
Record views
328
Files downloads
355
