Issues of fault diagnosis for dynamic systemsAirbus efforts toward advanced fault diagnosis for flight control system actuatorsModel based fault diagnosis for aerospace systems: A survey, International Conference on Recent Advances in Aerospace Actuation Systems and Components, pp.1329-1360, 2000. ,
Leaks detection in Diesel air path using, 2012. ,
Real-time diagnosis and fault detection for the monitoring of the wind turbineCaractérisation non destructive des bétons par propagation d'ondes ultrasonoresMonitoring behavior of grouted anchors using vibrating-wire gaugesThe design, construction and performance of a vibrating-wire earh pressure cell, Marquardt neural networks IEEE Intelligent Vehicles Symposium, Alcala de Henares 19ème Congrès Français de mécanique, pp.466-475, 1969. ,
Making Principal component analysis Principal component analysis of variation pattern among Cola nitida, Cola acuminata (Sterculiaceae) and their interspecific hybrids doi: 10.1002/fedr Multivariate data analysis of aerosols collected on the Gulf of Finland Principal component analysis for intervalvalued observations. Statistical Analysis Data Mining Application of principal component analysis to radio properties of Quasars Subspace approach to multidimensional fault identification and reconstruction Identification of faulty sensors using principal component analysis Optimal tuning for an abrupt change detection algorithm: Application to an underground gallery structure health monitoring, Conference on Control and Fault-Tolerant Systems (SysTol), pp.2-18, 1996. ,
