Mechanical Vibration Sensing for Structural Health Monitoring Using a Millimeter-Wave Doppler Radar Sensor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In-service detection of material failures based on an integrated sensor network is the main goal of structural health monitoring (SHM). In this paper, we report on a millimeter-wave Doppler radar sensor operating at 102GHz that enables accurate and non-contact mechanical vibration sensing. Thanks to the unique properties of mm-wave radiation it is possible to penetrate through many non-conducting materials. In contrast to Laser-Doppler-vibrometry this modality enables non-contact vibration measurements behind barriers such as glass-fiber-reinforced plastics, sandwich structures, foams, ceramics etc. Experimental measurements are shown for damage detection and non-linear motion sensing. The unique properties of mm-wave radiation promise great potential for a multitude of future SHM-applications.
0201.pdf (2.86 Mo) Télécharger le fichier
hal-01022029 , version 1 (10-07-2014)
  • HAL Id : hal-01022029 , version 1
Jochen Moll, Kaspar Bechtel, Bernd Hils, Viktor Krozer. Mechanical Vibration Sensing for Structural Health Monitoring Using a Millimeter-Wave Doppler Radar Sensor. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022029⟩
584 Consultations
1323 Téléchargements
