Fibre optic methods for structural health monitoring ,
Quantitative strain measurement and crack detection in RC structures using a truly distributed fiber optic sensing system, Construction and Building Materials, vol.37, pp.916-923, 2012. ,
DOI : 10.1016/j.conbuildmat.2012.05.029
Die Nietkraftverteilung in zugbeanspruchten Nietverbindungen mit konstanten Laschenquerschnitten, Luftfahrtforschung, vol.15, pp.41-47, 1938. ,
Mechanics of Bond and Interface Shear Transfer in Optical Fiber Sensors, Journal of Engineering Mechanics, vol.124, issue.4, 1998. ,
DOI : 10.1061/(ASCE)0733-9399(1998)124:4(385)
Mechanical Property and Strain Transferring Mechanism in Optical Fiber Sensors ,
DOI : 10.5772/27731
Investigation of strain transmission of surface-bonded FBGs used as strain sensors, Sensors and Actuators A: Physical, vol.149, issue.2, pp.201-207, 2009. ,
DOI : 10.1016/j.sna.2008.11.011
Effect of Coating on the Strain Transfer of Optical Fiber Sensors, Sensors, vol.11, issue.12, pp.6926-6967, 2011. ,
DOI : 10.3390/s110706926
Theoretical and Experimental Investigations into Crack Detection with BOTDR-Distributed Fiber Optic Sensors, Journal of Engineering Mechanics, vol.139, issue.12, pp.1797-1807, 2013. ,
DOI : 10.1061/(ASCE)EM.1943-7889.0000622
Improved theoretical solutions of FRP-to-concrete interfaces, Proc. of the International Symposium on Bond Behaviour of FRP in Structures, BBFS 2005, pp.97-102 ,
Analysis of the strain transfer mechanism between a truly distributed optical fiber sensor and the surrounding medium, 2012. ,
Mesures réparties de déformation par fibre optique, pp.97-130, 2013. ,
Stress analysis of lap joints involving natural fibre reinforced interface layers, Composites Part B: Engineering, vol.36, issue.1, pp.1-7, 2005. ,
DOI : 10.1016/j.compositesb.2004.04.011
Influence of the properties of externally bonded CFRP on the shear behavior of concrete/composite adhesive joints, Composites Part B: Engineering, vol.41, issue.5, pp.354-362, 2010. ,
DOI : 10.1016/j.compositesb.2010.03.007
URL : https://hal.archives-ouvertes.fr/hal-00587872
