New interface
Conference papers
Identification of inhomogeneous concrete cover by non-contact ultrasonic method
Abstract : Concrete cover degradation is induced by aggressive agents in ambiance, chemicals, moisture, or temperature variations. Due to this degradation concrete becomes inhomogeneous and usually a thin surface layer appears with porosity and elastic modulus different than the properties of deeper sound concrete. Therefore the on-site nondestructive evaluation of concrete cover is important to monitor the integrity of concrete structures and prevent their irreversible damage. In this paper the methodology applied by the classical technique used for ground structure recovery called Multichannel Analysis of Surface Waves (MASW) is used as the NDT tool to characterize the thickness and elastic modulus of concrete cover. The procedure consists in generation and reception of surface waves within the required frequency band, using the non-contact transducers which scan evaluated profiles. Then the phase velocity dispersion characteristic V(f) is extracted, and concrete cover is characterized using as the proposed velocity gradient. The dispersion characteristics are exploited by the inversion software in order to obtain the variation of shear wave velocity as a function of depth.
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01022073
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Thursday, July 10, 2014 - 10:04:00 AM
Last modification on : Tuesday, October 25, 2022 - 11:58:11 AM
Long-term archiving on: : Friday, October 10, 2014 - 11:06:36 AM
File
0392.pdf
Identifiers
  • HAL Id : hal-01022073, version 1
Citation
Bogdan Piwakowski, Qiang Liu, Jean-Paul Balayssac, Géraldine Villain, Vincent Garnier, et al.. Identification of inhomogeneous concrete cover by non-contact ultrasonic method. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022073⟩
Share
Metrics
Record views
433
Files downloads
191
