J. M. Caicedo, S. J. Dyke, S. J. Moon, L. A. Bergman, G. Turan et al., Phase II benchmark control problem for seismic response of cable-stayed bridges, Journal of Structural Control, vol.27, issue.3-4, pp.3-4, 2003.
DOI : 10.1002/stc.23
M. P. Limongelli, Seismic health monitoring of an instrumented multistorey building using the Interpolation Method, Earthquake Engng. Struct, 2014.
M. P. Limongelli, Frequency response function interpolation for damage detection under changing environment, Mechanical Systems and Signal Processing, vol.24, issue.8, 2010.
DOI : 10.1016/j.ymssp.2010.03.004
M. P. Limongelli, The interpolation damage detection method for frames under seismic excitation, Journal of Sound and Vibration, vol.330, issue.22, pp.5474-5489, 2011.
DOI : 10.1016/j.jsv.2011.06.012
M. Domaneschi, M. P. Limongelli, and L. Martinelli, Damage detection in a suspension bridge model using the interpolation damage detection method, Bridge Maintenance, 2012.
DOI : 10.1201/b12352-452
M. P. Limongelli, Two Dimensional Damage Localization Using the Interpolation Method, Key Engineering Materials, vol.569, issue.570, 2014.
DOI : 10.4028/www.scientific.net/KEM.569-570.860
M. Domaneschi and L. Martinelli, Performance comparison of passive control schemes for the numerically improved ASCE cable-stayed bridge model, Earthquakes and Structures, vol.3, issue.2, pp.181-201, 2012.
DOI : 10.12989/eas.2012.3.2.181
M. Domaneschi and L. Martinelli, Deepening the ASCE bridge benchmark: transversal response under seismic loading, Journal of Bridge Engineering ASCE, vol.19, issue.3, pp.1943-55920000532, 2014.
M. Domaneschi, M. P. Limongelli, and L. Martinelli, Vibration based damage localization using MEMS on a suspension bridge model, Smart Structures and Systems, vol.12, issue.6, pp.679-694, 2013.
DOI : 10.12989/sss.2013.12.6.679
M. Ismail, J. Rodellar, G. Carusone, M. Domaneschi, and L. Martinelli, Characterization, modeling and assessment of Roll-N-Cage isolator using the cable-stayed bridge benchmark, Acta Mechanica, vol.18, issue.107, pp.525-547, 2013.
DOI : 10.1007/s00707-012-0771-4
