Application of surface wave transmission measurements for crack depth determination in concrete, Materials Journal, vol.97, pp.127-135, 2000. ,
Estimating the sizes of surface cracks based on Hall element measurements of the leakage magnetic field and a dipole model of a crack, Applied Physics A: Materials Science & Processing, vol.74, issue.2, pp.169-176, 2002. ,
DOI : 10.1007/s003390100899
Three-dimensional Analysis of Fatigue Crack Propagation using X-Ray Tomography, Digital Volume Correlation and Extended Finite Element Simulations, Procedia IUTAM, Symposium on Full-field Measurements and Identification in Solid Mechanics, pp.151-158, 2012. ,
DOI : 10.1016/j.piutam.2012.05.017
Z-set : une suite logicielle pour la mécanique des matériaux et le calcul de structures, CSMA 2013, 11e Colloque National en Calcul des Structures, 2013. ,
An Algorithm for Least-Squares Estimation of Nonlinear Parameters, Journal of the Society for Industrial and Applied Mathematics, vol.11, issue.2, pp.431-441, 1963. ,
DOI : 10.1137/0111030
