An Improved Error Model for Noisy Channel Spelling Correction, Proceedings of the 38th Annual Meeting on Association for Computational Linguistics (ACL'00), pp.286-293, 2000. ,
Spelling correction as an iterative process that exploits the collective knowledge of web users, Proceedings of Proceedings of the 2004 Conference on Empirical Methods in Natural Language Processing, pp.293-300, 2004. ,
ChemicalTagger : A tool for semantic text-mining in chemistry, Journal of Cheminformatics, vol.3, issue.17, 2011. ,
A voting system for automatic OCR correction, Proceedings of the Workshop On Information Retrieval and OCR : From Converting Content to Grasping Meaning, pp.1-21, 2002. ,
OCR error correction using a noisy channel model, Proceedings of the Second International Conference on Human Language Technology Research (HLT'02), pp.257-262, 2002. ,
Improving optical character recognition through efficient multiple system alignment, Proceedings of the 9th ACM/IEEE-CS Joint Conference on Digital Libraries (JCDL'09), pp.231-240, 2009. ,
Named entity recognition from diverse text types, Proceedings of the Recent Advances in Natural Language Processing Conference, pp.257-274, 2001. ,
The same is not the same?postcorrection of alphabet confusion errors in mixed-alphabet ocr recognition, Proceedings of the 8th International Conference on Document Analysis and Recognition (ICDAR'05), pp.406-410, 2006. ,
Chemspot : a hybrid system for chemical named entity recognition, Bioinformatics, p.28, 2012. ,
SxPipe 2 : architecture pour le traitement pré-syntaxique de corpus bruts, Traitement Automatique des Langues, vol.49, issue.2, pp.155-188, 2008. ,
Introduction to the CoNLL-2003 shared task : Language-independent named entity recognition, Proceedings of the seventh conference on Natural language learning at HLT-NAACL 2003 (CONLL'03), pp.142-147, 2003. ,
Lexical postcorrection of ocr-results : the web as a dynamic secondary dictionary ?, Proceedings of the Seventh International Conference on Document Analysis and Recognition (ICDAR'03), pp.1133-1137, 2003. ,
