Discrete Markov image modeling and inference on the quadtree, IEEE Transactions on Image Processing, vol.9, issue.3, pp.390-404, 2000. ,
DOI : 10.1109/83.826777
A multiscale random field model for Bayesian image segmentation, IEEE Transactions on Image Processing, vol.3, issue.2, pp.162-177, 1994. ,
DOI : 10.1109/83.277898
An introduction to copulas, 2006. ,
DOI : 10.1007/978-1-4757-3076-0
Stochastic versions of the em algorithm: an experimental study in the mixture case, Journal of Statistical Computation and Simulation, vol.67, issue.4, pp.287-314, 1996. ,
DOI : 10.1214/aos/1176346060
URL : https://hal.archives-ouvertes.fr/hal-00693519
Supervised high resolution dual polarization SAR image classification by finite mixtures and copulas Supervised Classification of Multisensor and Multiresolution Remote Sensing Images with a Hierarchical Copula-based Approach A Neural- Statistical Approach to Multitemporal and Multisource Remote- Sensing Image Classification, IEEE J. Sel. Top. Signal Proc. IEEE Trans. Geosci. Remote Sensing IEEE Transactions on Geoscience and Remote Sensing, vol.5, issue.37 3, pp.554-566, 1999. ,
Markov random fields in image segmentation Weight parameter optimization by the Ho-Kashyap algorithm in MRF models for supervised image classification Multiscale unsupervised change detection on optical images by Markov random fields and wavelets Unsupervised Parallel Image Classification Using Markovian Models, Foundations and Trends in Signal Processing IEEE Trans. Geosci. Remote Sensing IEEE Geosci. Remote Sensing Letters Pattern Recognition, vol.5, issue.324, pp.1-155, 1999. ,
