Computing Persistent Homology with Various Coefficient Fields in a Single Pass
This article introduces an algorithm to compute the persistent homology of a filtered complex with various coefficient fields in a single matrix reduction. The algorithm is output-sensitive in the total number of distinct persistent homological features in the diagrams for the different coefficient fields. This computation allows us to infer the prime divisors of the torsion coefficients of the integral homology groups of the topological space at any scale, hence furnishing a more informative description of topology than persistence in a single coefficient field. We provide theoretical complexity analysis as well as detailed experimental results. The code is part of the Gudhi library.
On introduit un algorithme de calcul de l'homologie persistante d'un complexe filtré sur plusieurs corps en n'utilisant qu'une seule réduction de matrice. On obtient ainsi, sans coût supplémentaire,de l'information sur les coefficients de torsion. L'algorithme a été programmé et le code fait partie de la bibliothèque Gudhi.
main.pdf (381.08 Ko)
Télécharger le fichier
Format : Figure, Image
