Comparative study of vibration-based parametric identification techniques for a three-dimensional frame structure, Structural Control and Health Monitoring, vol.16, issue.5, pp.579-608, 2012. ,
DOI : 10.1002/stc.449
Seismic Response of a Historical Masonry Minaret using a Finite Element Model Updated with Operational Modal Testing, Journal of Vibration and Control, vol.17, issue.1, pp.129-149, 2011. ,
DOI : 10.1177/1077546309353288
System Identification Methods for (Operational) Modal Analysis: Review and Comparison, Archives of Computational Methods in Engineering, vol.15, issue.5, pp.51-124, 2012. ,
DOI : 10.1007/s11831-012-9069-x
Automatic Modal Analysis: Reality or Myth?, Proceedings of the 25th International Modal Analysis Conference, 2007. ,
Modal Identification through Ambient Vibration: Comparative Study, Proceedings of the 24th International Modal Analysis Conference, 2009. ,
DOI : 10.1061/(ASCE)0733-9399(2009)135:8(759)
Discriminating physical poles from mathematical poles in high order systems: use and automation of the stabilization diagram, Proceedings of the 21st IEEE Instrumentation and Measurement Technology Conference (IEEE Cat. No.04CH37510) ,
DOI : 10.1109/IMTC.2004.1351525
An eigensystem realization algorithm for modal parameter identification and model reduction, Journal of Guidance, Control, and Dynamics, vol.8, issue.5, pp.620-627, 1985. ,
DOI : 10.2514/3.20031
MIMO LMS-ARMAX IDENTIFICATION OF VIBRATING STRUCTURES???PART II: A CRITICAL ASSESSMENT, Mechanical Systems and Signal Processing, pp.737-758, 2001. ,
DOI : 10.1006/mssp.2000.1385
MIMO LMS-ARMAX IDENTIFICATION OF VIBRATING STRUCTURES???PART I: THE METHOD, Mechanical Systems and Signal Processing, vol.15, issue.4, pp.723-735, 2001. ,
DOI : 10.1006/mssp.2000.1382
Model reduction and energy analysis as a tool to detect spurious modes, Proceedings of the 2002 International Conference on Noise and Vibration Engineering, 2002. ,
Reference-based combined deterministic???stochastic subspace identification for experimental and operational modal analysis, Mechanical Systems and Signal Processing, vol.22, issue.3, pp.617-637, 2008. ,
DOI : 10.1016/j.ymssp.2007.09.004
On the use of dispersion analysis for model assessment in structural identification, Journal of Vibration and Control, vol.19, issue.15, pp.2270-2284, 2013. ,
DOI : 10.1177/1077546313501536
VAR Based State???space Structures: Realization, Statistics and Spectral Analysis, Lecture Notes in Electrical Engineering, vol.85, pp.301-315, 2011. ,
DOI : 10.1007/978-3-642-19730-7_21
Identification of the deterministic part of MIMO state space models given in innovations form from input-output data, Automatica, vol.30, issue.1, pp.61-74, 1994. ,
DOI : 10.1016/0005-1098(94)90229-1
COMPARISON STUDY OF SUBSPACE IDENTIFICATION METHODS APPLIED TO FLEXIBLE STRUCTURES, Mechanical Systems and Signal Processing, vol.12, issue.5, pp.679-692, 1998. ,
DOI : 10.1006/mssp.1998.0169
Matrix Analysis and Applied Linear Algebra, Society for Industrial and Applied Mathematics, 2000. ,
DOI : 10.1137/1.9780898719512
Dynamics of Structures, Journal of Applied Mechanics, vol.44, issue.2, 2003. ,
DOI : 10.1115/1.3424082
Using subspace methods in the identification and modal analysis of structures DaISy: Database for the Identification of Systems, Proceedings of the 15th International Modal Analysis ConferenceUsed dataset: Experiment on a Steel Subframe Flexible structure, section Mechanical Systems, pp.96-109, 1997. ,
