Physical interpretation of independent component analysis in structural dynamics, Mechanical Systems and Signal Processing, pp.1561-1575, 2007. ,
DOI : 10.1016/j.ymssp.2006.07.009
Independent component analysis: algorithms and applications, Neural Networks, vol.13, issue.4-5, pp.411-430, 2000. ,
DOI : 10.1016/S0893-6080(00)00026-5
Blind source separation based vibration mode identification, Mechanical Systems and Signal Processing, pp.3072-3087, 2007. ,
DOI : 10.1016/j.ymssp.2007.05.007
Output-only modal analysis using blind source separation techniques, Mechanical Systems and Signal Processing, pp.2335-2358, 2007. ,
DOI : 10.1016/j.ymssp.2006.12.005
A framework for blind modal identification using joint approximate diagonalization, Mechanical Systems and Signal Processing, vol.22, issue.7, pp.1526-1548, 2008. ,
DOI : 10.1016/j.ymssp.2008.01.010
An investigation of the effects of traffic induced local dynamics on global damping estimates using operational modal analysis, Mechanical Systems and Signal Processing, vol.41, issue.1-2, pp.433-453, 2013. ,
DOI : 10.1016/j.ymssp.2013.07.013
Blind Modal Identification Applied to Output-Only Building Vibration, 28th IMAC, A Conference on Structural Dynamics, pp.157-176, 2010. ,
DOI : 10.1007/978-1-4419-9834-7_15
Wavelet-based blind identification of the UCLA Factor building using ambient and earthquake responses, Smart Materials and Structures, vol.19, issue.2, p.25005, 2010. ,
DOI : 10.1088/0964-1726/19/2/025005
Damage detection using blind source separation techniques, 29th IMAC, A Conference on Structural Dynamics, pp.45-56, 2011. ,
A study and extension of second-order blind source separation to operational modal analysis, Journal of Sound and Vibration, vol.332, issue.4, pp.1079-1106, 2013. ,
DOI : 10.1016/j.jsv.2012.09.016
URL : https://hal.archives-ouvertes.fr/hal-00926071
