N. Huang, Z. Shen, S. Long, M. Wu, H. Shih et al., The empirical mode decomposition and the Hilbert spectrum for nonlinear and non-stationary time series analysis, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.454, issue.1971, pp.903-995, 1998.
DOI : 10.1098/rspa.1998.0193
Z. Wu and N. Huang, ENSEMBLE EMPIRICAL MODE DECOMPOSITION: A NOISE-ASSISTED DATA ANALYSIS METHOD, Advances in Adaptive Data Analysis, vol.01, issue.01, pp.1-41, 2009.
DOI : 10.1142/S1793536909000047
H. Teager, So me observations on oral air flow during phonation . Acoustics, speech and signal processing, pp.599-601, 1980.
J. Kaiser, On a simple algorith m to calculate the energy of a signal, Int. Conf. on Acoustics, speech and signal processing, 1990.
C. Junsheng, Y. Dejie, and Y. Yu, The application of energy operator demodulation approach based on EMD in machinery fault diagnosis . Mechanical systems and signal processing, pp.668-677, 2007.
H. Li, L. Fu, and Y. Zhang, Bearing fault diagnosis based on Teager energy operato demodulation technique . International conference on measuring technology and mechatronics automation, 2009.
H. Li, Y. Zhang, and H. Zheng, BEARING FAULT DETECTION AND DIAGNOSIS BASED ON TEAGER???HUANG TRANSFORM, International Journal of Wavelets, Multiresolution and Information Processing, vol.07, issue.05, p.643, 2009.
DOI : 10.1142/S0219691309003173
Z. Feng, T. Wang, M. Zuo, F. Chu, and S. Yan, Teager energy spectrum for fault d iagnosis of rolling element bearings, International conference on damage assessment of structures (DAMAS), 2010.
H. Liu, J. Wang, and C. Lu, Rolling bearing fault detection based on the Teager energy operator and Elman neural network, Mathematical problems in engineering, 2013.
P. Rodriguez, J. Alonso, M. Ferrer, and C. Travieso, Application of the Teager???Kaiser energy operator in bearing fault diagnosis, ISA Transactions, vol.52, issue.2, pp.278-284, 2013.
DOI : 10.1016/j.isatra.2012.12.006
D. Kwak, D. Lee, J. Ahn, and B. Koh, Fault Detection of Roller-Bearings Using Signal Processing and Optimization Algorithms, Sensors, vol.14, issue.1, pp.283-298, 2014.
DOI : 10.3390/s140100283
A. V. Vapnik, The nature of statistical learning theory, 1995.
A. Widodo and B. Yang, Support vector machine in machine condition monitoring and fault and d iagnosis, Mechanical Systems and Signal Processing, pp.2560-2574, 2007.
J. C. Burges, A tutorial on support vector mach ines for pattern recognition, Data Mining and Knowledge Discovery, 1998.
B. Scholkopf, R. Williamson, A. Smola, J. S. Taylor, and J. Platt, Support vector method for novelty detection, Advances in Neural Information Processing Systems, pp.582-586, 2000.
H. J. Shin, D. Eo-m, and S. Kim, One-class support vector machines???an application in machine fault detection and classification, Computers & Industrial Engineering, vol.48, issue.2, pp.395-408, 2005.
DOI : 10.1016/j.cie.2005.01.009
P. Maragos, J. F. Kaiser, and T. F. Quatieri, On amplitude and frequency demodulation using energy operators, IEEE Transactions on Signal Processing, vol.41, issue.4, pp.1532-1550, 1993.
DOI : 10.1109/78.212729
P. Maragos, J. F. Kaiser, and T. F. Quatieri, Energy separation in signal modulations with applicat ion to speech analysis, IEEE Transactions on Signal Processing, issue.10, pp.41-3024, 1993.
A. Tabrizi, L. Garibald-i, A. Fasana, and S. Marchesiello, Investigating of a sensitive intelligent method for damage identification of roller bearing under various external conditions . Italian association of theoretical and applied mechanics (Aimeta) congress, pp.17-20, 2013.
