Journal articles
A temporal multi-frequency encoding technique for chipless RFID based on c-sections
Abstract : A time domain chipless RFID tag based on cascaded microstrip coupled transmission line sections (C-sections), which can operate in multi-frequency bands is presented. The group delay characteristics of the C-sections are exploited to generate the tag Identification (ID). The tag comprises cascaded commensurate group of C-sections and two cross-polarized ultra wide-band (UWB) antennas. Since the proposed tag can operate in multi-frequency bands, this paper proves the possibility of increasing the coding capacity compared to the existing time domain designs. A tag operating at ISM (Industrial Scientific and Medical) bands at 2.45 GHz and 5.8 GHz together with conformance of frequency and power regulations is discussed elaborately. The prototype of the device is fabricated and validated experimentally. The time domain characteristic of the tag is also validated experimentally by interrogating a short pulse. Furthermore, measurement results using commercial Ultra Wide Band (UWB) radar which can be used as a chipless RFID reader is also incorporated. The obtained results confirm the concept and the possibility of using temporal multi-frequency in chipless RFID. (25 References).
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01023131
Contributor : Valence Lcis Connect in order to contact the contributor
Submitted on : Friday, July 11, 2014 - 3:12:26 PM
Last modification on : Friday, November 6, 2020 - 4:37:51 AM
Identifiers
  • HAL Id : hal-01023131, version 1
Collections
UGA | LCIS
Citation
Raji Sasidharan Nair, Etienne Perret, Smail Tedjini. A temporal multi-frequency encoding technique for chipless RFID based on c-sections. Progress In Electromagnetics Research B, EMW Publishing, 2013. ⟨hal-01023131⟩
Share
Metrics
Record views
42
