Regularization of chattering phenomena via bounded variation controls
1 Motivation what is chattering? how often does it occur? 2 Convergence results convergence for the perturbed problem rate of convergence and switching times 3 Open problems rate of convergence for the perturbed problem generic rate of convergence
Optimisation et contrôle [math.OC]
