New interface
Documents associated with scientific events
Quantitative DEM of dense granular packings with a multiple contacts force model
Abstract : We present a new force model for performing quantitative simulations of dense granular materials. Interactions between multiple contacts on the same grain are explicitly taken into account. Our readily applicable method retains all the advantages of discrete simulations and does not require the use of costly finite elements. The new model accurately reproduces the experimental measurements we recently demonstrated, including contact force distributions in full 3D, at all compression levels up to the experimental maximum limit of 13%. Comparisons with the traditional non-deformable spheres approach is provided, as well as with alternative models for interactions between multiple contacts. The success of our model compared to these alternatives provides new insights for dense granular packings.
Complete list of metadata
https://hal.inria.fr/hal-01024663
Contributor : Nicolas Brodu Connect in order to contact the contributor
Submitted on : Wednesday, July 16, 2014 - 2:59:30 PM
Last modification on : Friday, November 18, 2022 - 9:25:18 AM
Long-term archiving on: : Tuesday, October 20, 2015 - 5:45:20 PM
File
mgmas14_brodu.pdf
Identifiers
  • HAL Id : hal-01024663, version 1
Collections
Citation
Nicolas Brodu, Joshua Dijksman, Robert Behringer. Quantitative DEM of dense granular packings with a multiple contacts force model. MGMAS 2014 - Modeling Granular Media Across Scales, Jul 2014, Montpellier, France. ⟨hal-01024663⟩
Share
Metrics
Record views
90
Files downloads
55
