New interface
Preprints, Working Papers, ...
Gaussian and non-Gaussian processes of zero power variation, and related stochastic calculus.
Abstract : We consider a class of stochastic processes $X$ defined by $X\left( t\right) =\int_{0}^{T}G\left( t,s\right) dM\left( s\right) $ for $t\in\lbrack0,T]$, where $M$ is a square-integrable continuous martingale and $G$ is a deterministic kernel. Let $m$ be an odd integer. Under the assumption that the quadratic variation $\left[ M\right] $ of $M$ is differentiable with $\mathbf{E}\left[ \left\vert d\left[ M\right] (t)/dt\right\vert ^{m}\right] $ finite, it is shown that the $m$th power variation $$ \lim_{\varepsilon\rightarrow0}\varepsilon^{-1}\int_{0}^{T}ds\left( X\left( s+\varepsilon\right) -X\left( s\right) \right) ^{m} $$ exists and is zero when a quantity $\delta^{2}\left( r\right) $ related to the variance of an increment of $M$ over a small interval of length $r$ satisfies $\delta\left( r\right) =o\left( r^{1/(2m)}\right) $. When $M$ is the Wiener process, $X$ is Gaussian; the class then includes fractional Brownian motion and other Gaussian processes with or without stationary increments. When $X$ is Gaussian and has stationary increments, $\delta$ is $X$'s univariate canonical metric, and the condition on $\delta$ is proved to be necessary. In the non-stationary Gaussian case, when $m=3$, the symmetric (generalized Stratonovich) integral is defined, proved to exist, and its Itô formula is established for all functions of class $C^{6}$.
Document type :
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01024974
Contributor : Francesco Russo Connect in order to contact the contributor
Submitted on : Wednesday, July 16, 2014 - 10:34:52 PM
Last modification on : Wednesday, May 11, 2022 - 12:06:05 PM
Long-term archiving on: : Monday, November 24, 2014 - 5:06:11 PM
martESAIMrevision2HAL.pdf
Identifiers
  • HAL Id : hal-01024974, version 1
  • ARXIV : 1407.4568
Collections
Citation
Francesco Russo, Frederi Viens. Gaussian and non-Gaussian processes of zero power variation, and related stochastic calculus.. 2014. ⟨hal-01024974⟩
Share
Metrics
Record views
171
Files downloads
94
