Spread Transform and Roughness-based Shaping to Improve 3D Watermarking based on Quadratic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modulating the distances between the vertices and the center of mass of a triangular mesh is a popular approach to watermark 3D objects. Prior work has formulated this approach as a quadratic programming problem which minimizes the geometric distortion while embedding the watermark payload in the histogram of distances. To enhance this framework, we introduce two watermarking components, namely the spread transform and perceptual shaping based on roughness information. Benchmarking results showcase the benefits of these add-ons with respect to the fidelity-robustness trade-off.
Fichier non déposé
hal-01026353 , version 1 (21-07-2014)
  • HAL Id : hal-01026353 , version 1
Rolland-Nevière Xavier, Gwenaël Doërr, Pierre Alliez. Spread Transform and Roughness-based Shaping to Improve 3D Watermarking based on Quadratic Programming. International Conference on Image Processing, Oct 2014, paris, France. ⟨hal-01026353⟩
Collections
INRIA INRIA2
214 Consultations
0 Téléchargements
