Microsaccades enable efficient synchrony-based visual feature learning and detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
Fixational eye movements are common across vertebrates, yet their functional roles, if any, are debated. To investigate this issue, we exposed the Virtual Retina simulator to natural images, generated realistic drifts and microsaccades using the model of ref, and analyzed the output spike trains of the parvocellular retinal ganglion cells (RGC).
1471-2202-15-S1-P121.pdf (136.75 Ko) Télécharger le fichier
1471-2202-15-S1-P121.xml (8.4 Ko) Télécharger le fichier
Format : Autre
hal-01026508 , version 1 (21-07-2014)
  • HAL Id : hal-01026508 , version 1
Timothée Masquelier, Geoffrey Portelli, Pierre Kornprobst. Microsaccades enable efficient synchrony-based visual feature learning and detection. Twenty Third Annual Computational Neuroscience Meeting: CNS*2014, Jul 2014, Québec, Canada. 15 (Suppl 1), pp.P121, 2014, BMC Neuroscience. ⟨hal-01026508⟩
115 Consultations
95 Téléchargements
