A radix-independent error analysis of the Cornea-Harrison-Tang method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Mathematical Software Année : 2016
Assuming floating-point arithmetic with a fused multiply-add operation and rounding to nearest, the Cornea-Harrison-Tang method aims to evaluate expressions of the form $ab+cd$ with high relative accuracy. In this paper we provide a rounding error analysis of this method, which unlike previous studies is not restricted to binary floating-point arithmetic but holds for any radix $\beta$. We show first that an asymptotically optimal bound on the relative error of this method is $2u + O(u^2)$, where $u= \frac{1}{2}\beta^{1-p}$ is the unit roundoff in radix $\beta$ and precision $p$. Then we show that the possibility of removing the $O(u^2)$ term from this bound is governed by the radix parity and the tie-breaking strategy used for rounding: if $\beta$ is odd or rounding is \emph{to nearest even}, then the simpler bound $2u$ is obtained, while if $\beta$ is even and rounding is \emph{to nearest away}, then there exist floating-point inputs $a,b,c,d$ that lead to a relative error larger than $2u + \frac{2}{\beta} u^2 - 4u^3$. All these results hold provided underflows and overflows do not occur and under some mild assumptions on $p$ satisfied by IEEE 754-2008 formats.
Jeannerod2015c.pdf (428.43 Ko) Télécharger le fichier
hal-01050021 , version 1 (25-07-2014)
hal-01050021 , version 2 (23-09-2015)
Claude-Pierre Jeannerod. A radix-independent error analysis of the Cornea-Harrison-Tang method. ACM Transactions on Mathematical Software, 2016, ⟨10.1145/2824252⟩. ⟨hal-01050021v2⟩
451 Consultations
274 Téléchargements
