Scientific Computing on Itanium R -based Systems, 2002. ,
Accuracy and Stability of Numerical Algorithms, SIAM, 2002. ,
DOI : 10.1137/1.9780898718027
Error bounds on complex floating-point multiplication with an FMA, 2015. Preprint available at https ,
Further analysis of Kahan???s algorithm for the accurate computation of $2\times 2$ determinants, Mathematics of Computation, vol.82, issue.284, pp.2245-2264, 2013. ,
DOI : 10.1090/S0025-5718-2013-02679-8
On relative errors of floating-point operations: optimal bounds and applications, 2014. Preprint available at https ,
The Art of Computer Programming Seminumerical Algorithms, 1998. ,
On the error of computing ab + cd using Cornea, Harrison and Tang's method, ACM Trans. Math. Software, vol.417, issue.28, pp.1-7, 2015. ,
Accurate Floating-Point Summation Part I: Faithful Rounding, SIAM Journal on Scientific Computing, vol.31, issue.1, pp.189-224, 2008. ,
DOI : 10.1137/050645671
Floating-Point Computation, 1974. ,
