Image Processing and Analysis With Graphs: Theory and Practice (Digital Imaging and Computer Vision, 2012. ,
Real-time video abstraction, ACM Trans. Graph, vol.53 ,
Real-time edge-aware image processing with the bilateral grid, Proc. ACM SIGGRAPH, p.103, 2007. ,
Edge-Preserving Smoothing and Mean-Shift Segmentation of Video Streams, Proc. 10th Eur. Conf. Comput. Vis. (ECCV), pp.460-473, 2008. ,
DOI : 10.1007/978-3-540-88688-4_34
Shapeconstrained segmentation approach for arctic multiyear sea ice floe analysis, Proc. Int. Geosci. Remote Sens. Symp. (IGARSS), pp.4958-4961, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00729033
Motion segmentation and tracking using normalized cuts, Proc. 6th Int. Conf. Comput. Vis, pp.1154-1160, 1998. ,
Spatio-temporal segmentation of video by hierarchical mean shift analysis, Proc. Statist. Methods Video Process. Workshop (SMVP) ,
Efficient hierarchical graph-based video segmentation, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.2-3 ,
DOI : 10.1109/CVPR.2010.5539893
s i n g4 Dg r a p h cut segmentation: Application to ADNI, NeuroImage, issue.21, pp.109-118, 2010. ,
Diffusion snakes: Introducing statistical shape knowledge into the Mumford-Shah functional, International Journal of Computer Vision, vol.50, issue.3, pp.295-313, 2002. ,
DOI : 10.1023/A:1020826424915
Shape Priors for Level Set Representations, Proc. 7th Eur. Conf. Comput. Vis, pp.7-8 ,
DOI : 10.1007/3-540-47967-8_6
Representationa n dd e t e c t i o no fs h a p e si ni m a g e s, Ph.D. dissertation, Dept. Electr. Eng. Comput. Sci., Massachusetts Inst. Technol ,
Globally Optimal Image Segmentation with an Elastic Shape Prior, 2007 IEEE 11th International Conference on Computer Vision, pp.1-6 ,
DOI : 10.1109/ICCV.2007.4408972
Globally optimal shape-based tracking in real-time, 2008 IEEE Conference on Computer Vision and Pattern Recognition, pp.1-6 ,
DOI : 10.1109/CVPR.2008.4587443
S eg m entation o f im age ens em b les v ia latent atlas es, Med. Image Anal, vol.45, pp.6-11 ,
Enforcing Monotonous Shape Growth or Shrinkage in Video Segmentation, Procedings of the British Machine Vision Conference 2013 ,
DOI : 10.5244/C.27.27
URL : https://hal.archives-ouvertes.fr/hal-00856634
An experimental comparison of mincut/max-flow algorithms for energy minimization in vision, IEEE Trans. Pattern Anal. Mach. Intell, vol.69 ,
12. On the Max-Flow Min-Cut Theorem of Networks, Ann. Math. Studies, vol.8 ,
DOI : 10.1515/9781400881987-013
A new approach to the maximum-flow problem, J. ACM,v o l, vol.34, issue.5 ,
Exact optimization for markov random fields with convex priors, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.10, pp.1333-1336, 2003. ,
DOI : 10.1109/TPAMI.2003.1233908
Globally optimal segmentation of multiregion objects, Proc. 12th Int. Conf. Comput. Vis. (ICCV), pp.285-292, 2009. ,
Optimal surface segmentation in volumetric images?A graph-theoretic approach, IEEE Trans. Pattern Anal. Mach. Intell, vol.81, pp.1-1 ,
A Scalable graph-cut algorithm for N-D grids, 2008 IEEE Conference on Computer Vision and Pattern Recognition, pp.1-8, 2008. ,
DOI : 10.1109/CVPR.2008.4587464
Global optimizationf o rfi r s to r d e rM a r k o vr a n d o mfi e l d s with submodular priors, Proc. 12th Int. Workshop Combinat. Image Anal, pp.2-2 ,
Measure of the amount of ecological association between species, Ecology, vol.63 ,
Using temporal information in an automated classification of summer, marginal ice zone imagery, IGARSS '96. 1996 International Geoscience and Remote Sensing Symposium, pp.0-9 ,
DOI : 10.1109/IGARSS.1996.516260
Burned area mapping using multi-temporal moderate spatial resolution data???a bi-directional reflectance model-based expectation approach, Remote Sensing of Environment, vol.83, issue.1-2, pp.1-2, 2002. ,
DOI : 10.1016/S0034-4257(02)00077-9
Fire mapping for managers in North Australian savanna; An object orientated classification model for MODIS imagery, Proc ,
An active-fire based burned area mapping algorithm for the MODIS sensor, Remote Sensing of Environment, vol.113, issue.2 ,
DOI : 10.1016/j.rse.2008.10.006
Morphological Image Analysis,2 n de d .B e r l i n, 2003. ,
A Generative Model for Brain Tumor Segmentation in Multi-Modal Images, Proc. Med. Image Comput. Comput.-Assist ,
DOI : 10.1007/978-3-642-15745-5_19
URL : https://hal.archives-ouvertes.fr/hal-00813776
Adaptive segmentation of MRI data, IEEE Transactions on Medical Imaging, vol.15, issue.4, pp.429-442, 1996. ,
DOI : 10.1109/42.511747
Segmentation of brain tissue from magnetic resonance images, Medical Image Analysis, vol.1, issue.2 ,
DOI : 10.1016/S1361-8415(96)80008-9
T h ei n fl u e n c eo fv o l u m e t r i ct u m o rd o u b l i n g time, DNA ploidy, and histologic grade on the survival of patients with intracranial astrocytomas, Amer. J. Neuroradiol, pp.1001-1012, 1995. ,
Imageguidedpersonalizationofreaction-diffusion type tumor growth models using modified anisotropic Eikonal equations, IEEE Trans. Med. Imag, vol.91, pp.7-7 ,
