Abstract : Computational demanding public key cryptographic
algorithms, such as Rivest-Shamir-Adleman (RSA) and Elliptic Curve (EC)
cryptosystems, are critically dependent on modular multiplication for
their performance. Modular multiplication used in cryptography may be
performed in two different algebraic structures, namely GF(N) and
GF(2n), which normally require distinct hardware solutions for speeding
up performance. For both fields, Montgomery multiplication is the most
widely adopted solution, as it enables efficient hardware
implementations, provided that a slightly modified definition of modular
multiplication is adopted. In this paper we propose a novel unified
architecture for parallel Montgomery multiplication supporting both
GF(N) and GF(2n) finite field operations, which are critical for RSA ad
ECC public key cryptosystems. The hardware scheme interleaves
multiplication and modulo reduction. Furthermore, it relies on a
modified Booth recoding scheme for the multiplicand and a radix-4 scheme
for the modulus, enabling reduced time delays even for moderately large
operand widths. In addition, we present a pipelined architecture based
on the parallel blocks previously introduced, enabling very low clock
counts and high throughput levels for long operands used in
cryptographic applications. Experimental results, based on 0.18 μm CMOS
technology, prove the effectiveness of the proposed techniques, and
outperform the best results previously presented in the technical
literature.
https://hal.inria.fr/hal-01054277
Contributor : Hal Ifip <>
Submitted on : Tuesday, August 5, 2014 - 5:02:11 PM Last modification on : Thursday, March 5, 2020 - 5:40:22 PM Long-term archiving on: : Wednesday, November 26, 2014 - 12:40:28 AM
Alessandro Cilardo, Nicola Mazzocca. Time Efficient Dual-Field Unit for
Cryptography-Related Processing. 19th IFIP WG 10.5/IEEE International Conference on Very Large Scale Integration (VLSI-SoC), Oct 2008, Rhodes Island, India. pp.191-210, ⟨10.1007/978-3-642-12267-5_11⟩. ⟨hal-01054277⟩
