Dictionary matching and indexing with errors and don't cares, Proceedings of the thirty-sixth annual ACM symposium on Theory of computing , STOC '04, pp.90-100, 2004. ,
DOI : 10.1145/1007352.1007374
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.111.8692
String matching and other products, Proc. of the 7th SIAM-AMS Complexity of Computation, pp.113-125, 1974. ,
Algorithms on Strings, Trees, and Sequences, 1997. ,
DOI : 10.1017/CBO9780511574931
Matching a set of strings with variable length don't cares, Theoretical Computer Science, vol.178, issue.1-2, pp.129-154, 1997. ,
DOI : 10.1016/S0304-3975(97)88195-9
Flexible Pattern Matching in Strings, 2002. ,
DOI : 10.1017/CBO9781316135228
Efficient string matching, Combinatorial Algorithms on Words, NATO Advanced Science Institute Series F: Computer and System Sciences, pp.11-29, 1985. ,
Efficient string matching: an aid to bibliographic search, Communications of the ACM, vol.18, issue.6, pp.333-340, 1975. ,
DOI : 10.1145/360825.360855
Efficient filtering of XML documents for selective dissemination of information, Proc. of 26th Internat. Conf. on Very Large Data Bases, pp.53-64, 2000. ,
Filtering and transformation for high-volume XML message brokering ,
Path sharing and predicate evaluation for high-performance XML filtering, ACM Transactions on Database Systems, vol.28, issue.4, pp.467-516, 2003. ,
DOI : 10.1145/958942.958947
Processing XML streams with deterministic automata and stream indexes, ACM Transactions on Database Systems, vol.29, issue.4, pp.752-788, 2004. ,
DOI : 10.1145/1042046.1042051
Schema-conscious filtering of XML documents, Proceedings of the 12th International Conference on Extending Database Technology Advances in Database Technology, EDBT '09, pp.970-981, 2009. ,
DOI : 10.1145/1516360.1516471
XML data repository. The Database Research Group, 2006. ,
