A Three-Step Interaction Pattern for Improving Discoverability in Finger Identification Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
Identifying which fingers are in contact with a multi-touch surface provides a very large input space that can be leveraged for command selection. However, the numerous possibilities enabled by such vast space come at the cost of discoverability. To alleviate this problem, we introduce a three-step interaction pattern inspired by hotkeys that also supports feedforward. We illustrate this interaction with three applications allowing us to explore and adapt it in different contexts
paper.pdf (2.65 Mo) Télécharger le fichier
hal-01824250 , version 1 (27-06-2018)
Alix Goguey, Géry Casiez, Daniel Vogel, Fanny Chevalier, Thomas Pietrzak, et al.. A Three-Step Interaction Pattern for Improving Discoverability in Finger Identification Techniques . UIST 2014 - Adjunct Proceedings of the ACM Symposium on User Interface Software and Technology, Oct 2014, Honolulu, United States. ACM, ⟨10.1145/2658779.2659100⟩. ⟨hal-01824250⟩
341 Consultations
315 Téléchargements
