Modern concurrency abstractions for C#, ACM Transactions on Programming Languages and Systems, vol.26, issue.5, pp.769-804, 2004. ,
DOI : 10.1145/1018203.1018205
EventJava: An Extension of Java for Event Correlation, pp.570-594, 2009. ,
DOI : 10.1007/11531142_13
Implementing Joins using Extensible Pattern Matching . COORDINATION '08, pp.135-152 ,
Scala Actors: Unifying thread-based and event-based programming, Theoretical Computer Science, vol.410, issue.2-3, pp.202-220 ,
DOI : 10.1016/j.tcs.2008.09.019
URL : http://doi.org/10.1016/j.tcs.2008.09.019
The Expression of Common Concurrency Patterns in Join Java, pp.1021-1025 ,
Fairness for Chorded Languages, pp.86-105, 2009. ,
DOI : 10.1007/978-1-4612-4886-6
Specialization of CML Message-passing Primitives, pp.315-326, 2007. ,
Ptolemy: A Language with Quantified, Typed Events, pp.155-179 ,
DOI : 10.1007/978-3-540-70592-5_8
Design and evaluation of a wide-area event notification service, ACM Transactions on Computer Systems, vol.19, issue.3, pp.332-383, 2001. ,
DOI : 10.1145/380749.380767
Filtering and scalability in the ECO distributed event model, Proceedings International Symposium on Software Engineering for Parallel and Distributed Systems PDSE-99, pp.83-92, 2000. ,
DOI : 10.1109/PDSE.2000.847853
Type-based publish/subscribe, ACM Transactions on Programming Languages and Systems, vol.29, issue.1, 2007. ,
DOI : 10.1145/1180475.1180481
AmbientTalk: Object-oriented Event-driven Programming in Mobile Ad hoc Networks, XXVI International Conference of the Chilean Society of Computer Science (SCCC'07), 2007. ,
DOI : 10.1109/SCCC.2007.12
Actors with Multi-headed Message Receive Patterns, pp.315-330, 2008. ,
DOI : 10.1007/978-3-540-68265-3_20
Towards Expressive Publish/Subscribe Systems, pp.627-644, 2006. ,
DOI : 10.1007/11687238_38
Fault-tolerance in the Borealis Distributed Stream Processing System, pp.13-24, 2005. ,
JErlang: Erlang with Joins ,
DOI : 10.1007/978-3-642-13414-2_5
URL : https://hal.archives-ouvertes.fr/hal-01054623
Join Patterns for Visual Basic, pp.53-72, 2008. ,
The Reflexive Chemical Abstract Machine and the Join Calculus, POPL '96, pp.372-385 ,
Composite Subscriptions in Content-Based Publish/Subscribe Systems, pp.249-269, 2005. ,
DOI : 10.1049/ip-sen:20010241
Rete: A fast algorithm for the many pattern/many object pattern match problem, Artificial Intelligence, vol.19, issue.1, pp.17-37, 1982. ,
DOI : 10.1016/0004-3702(82)90020-0
Introduction to Algorithms, 2009. ,
Jingle Bells: Solving the Santa Claus Problem in Polyphonic C#, 2003. ,
Vhayu Velocity ? Algorithmic Trading Case Study, 2008. ,
