Optimization of Triangular Matrix Functions in BLAS Library on Loongson2F - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
BLAS (Basic Linear Algebra Subprograms) plays a very important role in scientific computing and engineering applications. ATLAS is often recommended as a way to generate an optimized BLAS library. Based on ATLAS, this paper optimizes the algorithms of triangular matrix functions on 750 MHZ Loongson 2F processor-specific architecture. Using loop unrolling, instruction scheduling and data pre-fetching techniques, computing time and memory access delay are both reduced, and thus the performance of functions is improved. Experimental results indicate that these optimization techniques can effectively reduce the running time of functions. After optimization, double-precision type function of TRSM has the speed of 1300Mflops, while single-precision type function has the speed of 1800Mflops. Compared with ATLAS, the performance of function TRSM is improved by 50% to 60%, even by 100% to 200% under small-scale input.
llncs.pdf (402.72 Ko) Télécharger le fichier
hal-01054958 , version 1 (11-08-2014)
Paternité
Yun Xu, Mingzhi Shao, Da Teng. Optimization of Triangular Matrix Functions in BLAS Library on Loongson2F. IFIP International Conference on Network and Parallel Computing (NPC), Sep 2010, Zhengzhou, China. pp.35-45, ⟨10.1007/978-3-642-15672-4_5⟩. ⟨hal-01054958⟩
65 Consultations
632 Téléchargements
