Power Efficient Scheduling for Hard Real-Time Systems on a Multiprocessor Platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An online, real-time scheduler is proposed to minimize the power consumption of a task set during execution on a multiprocessor platform. The scheduler is capable of handling the spectrum of task types (periodic, sporadic, and aperiodic) as well as supporting mutually exclusive, shared resources. The solution presented is a user adjustable scheduler which ranges from producing an optimal schedule which requires the minimum power during the worst case execution scenario to producing a suboptimal schedule which aggressively minimizes power during the typical execution scenario.
NPC10-22_in_EDAS.pdf (630.62 Ko) Télécharger le fichier
hal-01054985 , version 1 (11-08-2014)
Paternité
Peter J. Nistler, Jean-Luc Gaudiot. Power Efficient Scheduling for Hard Real-Time Systems on a Multiprocessor Platform. IFIP International Conference on Network and Parallel Computing (NPC), Sep 2010, Zhengzhou, China. pp.106-120, ⟨10.1007/978-3-642-15672-4_10⟩. ⟨hal-01054985⟩
101 Consultations
136 Téléchargements
