A process algebraic approach to software architecture design, 2010. ,
DOI : 10.1007/978-1-84800-223-4
Semiring-based constraint satisfaction and optimization, Journal of the ACM, vol.44, issue.2, pp.201-236, 1997. ,
DOI : 10.1145/256303.256306
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.4.3513
An algebraic semantics for MOF, Proceedings of the International Conference on Fundamental Aspects of Software Engineering (FASE'08), pp.377-391, 2008. ,
DOI : 10.1007/s00165-009-0140-9
URL : https://hal.archives-ouvertes.fr/hal-00567269
Style based architectural reconfigurations, EATCS, vol.94, pp.161-180, 2008. ,
Managing concurrency in temporal planning using planner-scheduler interaction, Artificial Intelligence, vol.173, issue.1, pp.1-44, 2009. ,
DOI : 10.1016/j.artint.2008.08.003
Fundamentals of Algebraic Graph Transformation, 2006. ,
Planning as Model Checking, Procceedings of the 5th European Conference on Planning (ECP'99), volume 1809 of LNCS, pp.1-20, 2000. ,
DOI : 10.1007/10720246_1
Which soft constraints do you prefer?, Proceedings of the 7th International Workshop on Rewriting Logic and its Applications (WRLA'08), pp.189-205, 2008. ,
Advances in Probabilistic Model Checking, International Conference on Verification, Model Checking, and Abstract Interpretation, 2010. ,
DOI : 10.1007/978-3-642-11319-2_5
A Rewriting Based Model for Probabilistic Distributed Object Systems, International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS'03), pp.32-46, 2003. ,
DOI : 10.1007/3-540-45657-0_17
Synchronization Algebras with Mobility for Graph Transformations, Proceedings of the 3rd Joint Workshops on Foundations of Global Ubiquitous Computing, pp.43-60, 2005. ,
DOI : 10.1016/j.entcs.2005.05.004
Quantitative mu-calculus and CTL defined over constraint semirings, TCS, vol.346, issue.1, pp.135-160, 2005. ,
Conditional rewriting logic as a unified model of concurrency, Theoretical Computer Science, vol.96, issue.1, pp.73-155359, 1992. ,
DOI : 10.1016/0304-3975(92)90182-F
A structural approach to operational semantics, Journal of Logic and Algebraic Programming, pp.60-6117, 2004. ,
Ein systolic-array-Algorithmus f??r das algebraische Wegproblem (k??rzeste Wege; Matrizeninversion), Computing, vol.10, issue.3, 1985. ,
DOI : 10.1007/BF02253318
Artificial Intelligence: A Modern Approach, 2003. ,
What models mean, IEEE Software, vol.20, issue.5, pp.26-32, 2003. ,
DOI : 10.1109/MS.2003.1231147
Executable structural operational semantics in Maude, The Journal of Logic and Algebraic Programming, vol.67, issue.1-2, pp.226-293, 2006. ,
DOI : 10.1016/j.jlap.2005.09.008
