Abstract : Many model checking methods have been developed and applied to analyze cryptographic protocols. Most of them can analyze only one attack trace of a found attack. In this paper, we propose a very simple but practical model checking methodology for the analysis of cryptographic protocols. Our methodology offers an efficient analysis of all attack traces for each found attack, and is independent to model checking tools. It contains two novel techniques which are on-the-fly trace generation and textual trace analysis. In addition, we apply our method to two case studies which are TMN authenticated key exchanged protocol and Micali's contract signing protocol. Surprisingly, it turns out that our simple method is very efficient when the numbers of traces and states are large. Also, we found many new attacks in those protocols.
https://hal.inria.fr/hal-01055153 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 11, 2014 - 4:29:00 PM Last modification on : Monday, March 11, 2019 - 11:48:20 AM Long-term archiving on: : Wednesday, November 26, 2014 - 10:15:12 PM
yongyuth Permpoontanalarp. On-the-Fly Trace Generation and Textual Trace Analysis and Their Applications to the Analysis of Cryptographic Protocols. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.201-215, ⟨10.1007/978-3-642-13464-7_16⟩. ⟨hal-01055153⟩
