1Software Engineering and Technology (TU/e Dept. of Mathematics and Computer Science Software Engineering and Technology HG 5.60 PO Box 513 5600 MB Eindhoven The Netherlands - Netherlands)
Abstract : In this paper, we propose the notion of partial time abstraction for timed process algebras, which introduces the possibility to abstract away parts of the timing of system behaviour. Adding this notion leads to so-called partially timed process algebras and partially timed labelled transition systems. We describe these notions, and generalise timed branching bisimilarity to partially timed branching bisimilarity, allowing the comparison of systems with partial timing. Finally, with several examples and a case study, we demonstrate how partial time abstraction can be a useful modelling technique for timed models, which can lead to rigorous minimisations of state spaces.
https://hal.inria.fr/hal-01055216 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 11, 2014 - 5:20:11 PM Last modification on : Friday, August 11, 2017 - 4:16:22 PM Long-term archiving on: : Wednesday, November 26, 2014 - 10:31:48 PM
Anton Wijs. Forgetting the Time in Timed Process Algebra. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.110-124, ⟨10.1007/978-3-642-13464-7_10⟩. ⟨hal-01055216⟩
