compution treedimensional finiteelement solution of permanent magnet machines, IEEE Trans on MAG17, issue.6, pp.2997-2999, 1997. ,
On Electromagnetic Fields Flux Density, Journal of Shanxi Institute of Education. IEEE. Trans. Magnetics, vol.33, issue.1, pp.3255-3258, 2009. ,
Biaxial stress effects on the magnetic properties of pure iron, IEEE. Trans. Magnetics, issue.1, pp.363251-3253, 2000. ,
Flux Control Model of A Ferrite Orthogonal Core, IEEE Tran.Magnetics, issue.6, pp.27-5259, 1991. ,
Observation and si2 mulation of solid2armature railgun performance, IEEE Trans on Magn, vol.35, issue.1, p.84289, 1999. ,
Current and heat transport in the solid2armature railgun, IEEE Transon Magn, issue.1, p.316452650, 1995. ,
