Light-weight Monocular 3D Display Unit Using Polypyrrole Linear Actuator
The human vision system has visual functions for
viewing 3D images with a correct depth. These functions are called
accommodation, vergence and binocular stereopsis. Most 3D display system
utilizes binocular stereopsis. We have developed a monocular 3D vision
system with accommodation mechanism, which is useful function for
perceiving depth. This vision unit needs an image shift optics for
generating monocular parallax images. But conventional image shift
mechanism is heavy because of its linear actuator. To improve this
problem, we developed a light-weight 3D vision unit for presenting
monocular stereoscopic images using a polypyrrole linear
actuator.
