Tolerance allocation methods for designers, 1999. ,
Evaluating inspection strategies by simulation, Manufacturing Systems, vol.29, issue.5, pp.421-425, 1999. ,
Simulation in Produktion und Logistik, 2004. ,
Optimal tolerance design by response surface methodology, International Journal of Production Research, vol.37, issue.14, pp.3275-3288, 1999. ,
DOI : 10.1080/002075499190284
Assembly Process Improvement by Means of Inspection Planning and Corresponding Tolerance Planning -A Modelling and Simulation Approach, 2007. ,
Ein Beitrag zur Entwicklung der Toleranzplanung auf der Basis von Risikobetrachtungen. Fortschritt-Berichte VDI, 1999. ,
Improved algorithm for tolerance allocation based on Monte Carlo simulation and discrete optimization, Computers & Industrial Engineering, vol.56, issue.4, 2008. ,
DOI : 10.1016/j.cie.2008.09.005
