Reconfigurable Manufacturing Systems. CIRP Annals - Manufacturing Technology, 1999. ,
DOI : 10.1007/978-3-642-55776-7_19
European precision assembly roadmap 2012. The Assembly-Net Consotium, 2002. ,
Process-Oriented Assembly System Concepts -The MarklV Approach. in ISATP, 2001. ,
Building a mini-assembly system from a technology construction kit. Assembly Automation, pp.43-48, 2004. ,
Reconfigurable manufacturing systems: the state of the art, International Journal of Production Research, vol.1, issue.4, pp.967-992, 2008. ,
DOI : 10.1080/00207540050028098
Feature-based description of modular fixturing elements: the key to an expert system for the automatic design of the physical fixture Advances in Engineering Software, pp.19-27, 1996. ,
The development of modular-based design in considering technology complexity, European Journal of Operational Research, vol.119, issue.3, pp.692-703, 1999. ,
DOI : 10.1016/S0377-2217(98)00350-6
Towards combinatorial analysis, adaptation, and planning of human-computer systems, Applied Intelligence, vol.16, issue.3, pp.235-247, 2002. ,
DOI : 10.1023/A:1014342101070
Entity-Based Models for Computer-Aided Design Systems, Journal of Computing in Civil Engineering, vol.12, issue.1, pp.30-41, 1998. ,
DOI : 10.1061/(ASCE)0887-3801(1998)12:1(30)
Case-based reasoning is a methodology not a technology. Knowledge- Based Systems, pp.303-308, 1999. ,
Concurrent Line-Balancing, Equipment Selection and Throughput Analysis for Multi-Part Optimal Line Design. The International Journal for Manufacturing Science & Production, pp.71-81, 2004. ,
A stochastic model for deciding an optimal production order and its corresponding configuration in a reconfigurable manufacturing system with multiple product groups, International Conference on Agile, Reconfigurable Manufacturing, 2003. ,
A stochastic model of a reconfigurable manufacturing system Part I, a framework, International Journal of Production Research, issue.10, pp.38-2273, 2000. ,
Development of reconfigurable machines The International Journal of Advanced Manufacturing Technology, 2007. ,
Applications of agent-based systems in intelligent manufacturing: An updated review, Advanced Engineering Informatics, vol.20, issue.4, pp.415-431, 2006. ,
DOI : 10.1016/j.aei.2006.05.004
Towards an Ontology Framework for the Integrated Design of Modular Assembly Systems, 2006. ,
Multiagent systems as computational organisations: the Gaia methodology, pp.136-171, 2005. ,
