Schabel: In-situ monitoring the drying kinetics of knife coated polymer-fullerene films for organic solar cells, APL, 2009. ,
Surface-Induced structure formation of polymer blends on patterned substrates, Nature, vol.391, issue.877, 1998. ,
Generation of Surface Energy Patterns by Single Pulse Laser Interference on Self-Assembled Monolayers, Langmuir, vol.24, issue.22, pp.13155-13160, 2008. ,
DOI : 10.1021/la801812j
Nanophase-Separated Polymer Films as High-Performance Antireflection Coatings, Science, vol.283, issue.5401, p.520, 1999. ,
DOI : 10.1126/science.283.5401.520
Controlled structuring of mica surfaces with the tip of an atomic force microscope by mechanically induced local etching, Surface and Interface Analysis, vol.36, issue.2, pp.189-192, 2004. ,
DOI : 10.1002/sia.1690
