Alignment Procedures for Micro-optics
The alignment procedure is an important step in the
process chain of the assembly of micro-optical components and has a
direct impact on the system performance of the micro-optical system, the
necessary assembly time and the manufacturing costs. For these reasons,
only alignment procedures that are adapted to the special requirements
of each assembly task will be able to save costs and attain the best
optical system performance. The paper describes the alignment methods
and illustrates the assembly procedures based on selected micro-optical
examples.
