Abstract : This paper describes the development of an
analytical model to describe a novel three-axis vibrating micro-scale
probe for micro-co-ordinate measuring machines (micro-CMMs). The
micro-CMM probe is vibrated in three axes, in order to address the
problems inherent with micro- and nano-scale co-ordinate measurements
caused by surface interaction forces. These surface forces have been
investigated and a mathematical model describing an ideal probing
situation has been developed. The vibration amplitude required for the
probe to overcome the surface interaction forces has been calculated
using this model. The results of initial vibration experiments are
reported and the suitability of the probe to counteract the surface
interaction forces is confirmed.
https://hal.inria.fr/hal-01055692 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, August 13, 2014 - 11:48:59 AM Last modification on : Wednesday, August 21, 2019 - 10:22:06 AM Long-term archiving on: : Thursday, November 27, 2014 - 12:26:39 AM
J. D. Claverley, A. Georgi, R. K. Leach. Modelling the Interaction Forces between an
Ideal Measurement Surface and the Stylus Tip of a Novel
Vibrating Micro-scale CMM Probe. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.131-138, ⟨10.1007/978-3-642-11598-1_15⟩. ⟨hal-01055692⟩
