Optimization and Approximation in Deterministic Sequencing and Scheduling: a Survey, Annals of Discrete Mathematics, pp.5287-5326, 1979. ,
DOI : 10.1016/S0167-5060(08)70356-X
Optimal two- and three-stage production schedules with setup times included, Naval Research Logistics Quarterly, vol.1, issue.1, pp.61-69, 1954. ,
DOI : 10.1002/nav.3800010110
Computers and intractability: A guide to the theory of NP- Completness, 1979. ,
A heuristic algorithm for the m-machine, n-job flow-shop sequencing problem, Omega, vol.11, issue.1, pp.91-95, 1983. ,
DOI : 10.1016/0305-0483(83)90088-9
A high quality solution constructive heuristic for flow shop sequencing, Journal of the Operational Research Society, vol.53, issue.12, pp.1374-1379, 2002. ,
DOI : 10.1057/palgrave.jors.2601466
Different initial sequences for the heuristic of Nawaz, Enscore and Ham to minimize makespan, idletime or flowtime in the static permutation flowshop sequencing problem, International Journal of Production Research, vol.41, issue.1, pp.121-148, 2003. ,
DOI : 10.1080/00207540210161650
Métodos heurísticos en la resolución del problema del taller mecánico, Estudios Empresariales, vol.5, pp.7-18, 1966. ,
-machine flow-shop problem, Production Planning & Control, vol.12, issue.7, pp.648-653, 2001. ,
DOI : 10.1057/jors.1965.8
URL : https://hal.archives-ouvertes.fr/hal-01105389
On the Flow-Shop Sequencing Problem with No Wait in Process???, Journal of the Operational Research Society, vol.23, issue.3, pp.323-331, 1972. ,
DOI : 10.1057/jors.1972.52
A Survey of Machine Scheduling Problems with Blocking and No-Wait in Process, Operations Research, vol.44, issue.3, pp.510-525, 1996. ,
DOI : 10.1287/opre.44.3.510
Flowshop scheduling with limited temporary storage, Journal of the ACM, vol.27, issue.3, pp.533-549, 1980. ,
DOI : 10.1145/322203.322213
Flowshop sequencing problems with limited buffer storage, International Journal of Production Research, vol.23, issue.11, pp.2085-2100, 1990. ,
DOI : 10.1080/00207549008942855
Sequencing in an Assembly Line with Blocking to Minimize Cycle Time, Operations Research, vol.37, issue.6, pp.925-936, 1989. ,
DOI : 10.1287/opre.37.6.925
An improved NEH heuristic to minimize makespan in permutation flow shops, Computers & Operations Research, vol.35, issue.9, pp.3001-3008, 2008. ,
DOI : 10.1016/j.cor.2007.01.020
Different behaviour of a double branch-and-bound algorithm on and problems, Computers & Operations Research, vol.34, issue.4, pp.938-53, 2007. ,
DOI : 10.1016/j.cor.2005.05.018
Note on the blocking flowshop problem Working paper, p.420, 2009. ,
