Knowledge Based Product and Process Engineering Enabling Design and Manufacture Integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthieu Bricogne
Farouk Belkadi
Magali Bosch-Mauchand
  • Fonction : Auteur
Benoît Eynard
After presenting reminders about product and process knowledge, this paper describes a specific knowledge called in this paper "shared knowledge", which is built from a mapping between both these knowledge. Then, a specific approach based on "workers" is proposed to extract data from the different IT components, to create this shared knowledge and to capitalize for the future development projects. Finally, different industrial examples are presented to illustrate the shared knowledge capitalization interest.
978-3-642-16358-6_59.pdf (358.75 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
Licence : CC BY - Paternité
hal-01055821 , version 1 (03-07-2023)
Paternité
Matthieu Bricogne, Farouk Belkadi, Magali Bosch-Mauchand, Benoît Eynard. Knowledge Based Product and Process Engineering Enabling Design and Manufacture Integration. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.473-480, ⟨10.1007/978-3-642-16358-6_59⟩. ⟨hal-01055821⟩
210 Consultations
12 Téléchargements
