Scheduling project networks with resource constraints and time windows, Annals of Operations Research, vol.24, issue.1, pp.201-240, 1988. ,
DOI : 10.1007/BF02283745
A New Approach for the Project Scheduling Problem with Generalized Precedence Relations, Proceedings of the 11th International Workshop on Project Management and Scheduling, 2008. ,
A new lower bound for the resource-constrained project scheduling problem with generalized precedence relations, Computers & Operations Research, vol.38, issue.1, 2009. ,
DOI : 10.1016/j.cor.2009.07.003
Minimizing the completion time of a project under resource constraints and feeding precedence relations: a Lagrangian relaxation based lower bound, 4OR, vol.103, issue.3, pp.sub- mitted, 2009. ,
DOI : 10.1007/s10288-011-0168-6
An Exact algorithm to minimize the makespan in project scheduling with scarce resources and feeding precedence relations, RR- 07, 2009. ,
A new formulation of the resource-unconstrained project scheduling problem with generalized precedence relations to minimize the completion time, Networks, vol.4, issue.4, 2010. ,
DOI : 10.1002/net.20388
Scheduling subject to resource constraints: classification and complexity, Discrete Applied Mathematics, vol.5, issue.1, pp.11-24, 1983. ,
DOI : 10.1016/0166-218X(83)90012-4
The Gantt Chart, 1954. ,
New Benchmark Results for the Resource-Constrained Project Scheduling Problem, Management Science, vol.43, issue.11, pp.1485-1492, 1997. ,
DOI : 10.1287/mnsc.43.11.1485
A Branch-and-Bound Procedure for the Generalized Resource-Constrained Project Scheduling Problem, Operations Research, vol.45, issue.2, pp.201-212, 1997. ,
DOI : 10.1287/opre.45.2.201
Project Scheduling -A Research Handbook, 2002. ,
Scheduling projects with generalized precedence relations - Exact and heuristic approaches, 1998. ,
A branch-and-bound procedure for the resource-constrained project scheduling problem with generalized precedence relations, European Journal of Operational Research, vol.111, issue.1, pp.152-174, 1998. ,
DOI : 10.1016/S0377-2217(97)00305-6
Project scheduling with time windows, 2002. ,
DOI : 10.1007/978-3-642-57506-8
The Analysis of Activity Networks Under Generalized Precedence Relations (GPRs), Management Science, vol.38, issue.9, pp.1245-1263, 1992. ,
DOI : 10.1287/mnsc.38.9.1245
Projectbeheersing in de Bouw, 1998. ,
The critical path method: Resource planning and scheduling, Industrial Scheduling, N.J, pp.347-365, 1963. ,
Computing lower bounds by destructive improvement: An application to resource-constrained project scheduling, European Journal of Operational Research, vol.112, issue.2, pp.322-346, 1999. ,
DOI : 10.1016/S0377-2217(97)00442-6
A Project-Oriented Decision Support System for Production Planning in Make-to-Order Manufacturing, ERCIM news 58, pp.66-67, 2004. ,
A branch-and-cut algorithm for scheduling of projects with variable-intensity activities, Mathematical Programming, vol.136, issue.3, pp.515-539, 2005. ,
DOI : 10.1007/s10107-004-0551-6
RCPS with Variable Intensity Activities and Feeding Precedence Constraints, Perspectives in Modern Project Scheduling, pp.105-129, 2006. ,
DOI : 10.1007/978-0-387-33768-5_5
Critical Chain. The North River Press, 1997. ,
Project Planning, Scheduling and Control. A Hands On Guide to Bringing Projects in on Time and on Budget, 1995. ,
Line of Balance Method, 1968. ,
Project management with CPM, PERT and precedence diagramming, 1983. ,
Project scheduling with time windows and scarce resources, Lecture Notes in Economics and Mathematical Systems, vol.508, 2002. ,
Scheduling of project networks, Annals of Operations Research, vol.27, issue.1, pp.227-252, 1985. ,
DOI : 10.1007/BF02022042
Quick Response Manufacturing, 1998. ,
