Joining the yellow hub: Uses of the Simple Application Messaging Protocol in Space Physics analysis tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Computing Année : 2014
The interest for data communication between analysis tools in planetary sciences and space physics is illustrated is this paper via several examples of the uses of SAMP. The Simple Application Messaging Protocol is developed in the frame of the IVOA from an earlier protocol called PLASTIC. SAMP enables easy communication and interoperability between astronomy software, stand-alone and web-based; it is now increasingly adopted by the planetary sciences and space physics community. Its attractiveness is based, on one hand, on the use of common file formats for exchange and, on the other hand, on established messaging models. Examples of uses at the CDPP and elsewhere are presented. The CDPP (Centre de Données de la Physique des Plasmas, http://cdpp.eu/), the French data center for plasma physics, is engaged for more than a decade in the archiving and dissemination of data products from space missions and ground observatories. Besides these activities, the CDPP developed services like AMDA (Automated Multi Dataset Analysis, http://amda.cdpp.eu/) which enables in depth analysis of large amount of data through dedicated functionalities such as: visualization, conditional search, cataloguing, etc. Besides AMDA, the 3DView (http://3dview.cdpp.eu/) tool provides immersive visualisations and is further developed to include simulation and observational data. These tools and their interactions with each other, notably via SAMP, are presented via science cases of interest to planetary sciences and space physics communities.
Genot_SAMP_AC2014_2.pdf (2.49 Mo) Télécharger le fichier
hal-01055883 , version 1 (17-07-2019)
Vincent Génot, N. André, B. Cecconi, M. Bouchemit, E. Budnik, et al.. Joining the yellow hub: Uses of the Simple Application Messaging Protocol in Space Physics analysis tools. Astronomy and Computing, 2014, 7-8, pp.62-70. ⟨10.1016/j.ascom.2014.07.007⟩. ⟨hal-01055883⟩
621 Consultations
110 Téléchargements
