Differential Power Analysis, CRYPTO 1999, pp.388-397, 1999. ,
DOI : 10.1007/3-540-48405-1_25
Correlation Power Analysis with a Leakage Model, CHES 2004, pp.135-152, 2004. ,
DOI : 10.1007/978-3-540-28632-5_2
Comparative Evaluation of Rank Correlation Based DPA on an AES Prototype Chip, ISC LNCS, vol.5222, pp.341-354, 2008. ,
DOI : 10.1007/978-3-540-85886-7_24
Mutual information analysis -a generic side-channel distinguisher, CHES LNCS, vol.5154, pp.426-442, 2008. ,
Mutual Information Analysis: How, When and Why?, LNCS, vol.5747, pp.429-443, 2009. ,
DOI : 10.1007/978-3-642-04138-9_30
Estimation of mutual information using kernel density estimators, Physical Review E, vol.52, issue.3, pp.2318-2321, 1995. ,
DOI : 10.1103/PhysRevE.52.2318
On Estimation of a Probability Density Function and Mode, The Annals of Mathematical Statistics, vol.33, issue.3, pp.1065-1076, 1962. ,
DOI : 10.1214/aoms/1177704472
Theorical and practical aspects of mutual information based side channel analysis, ACNS 2009, pp.499-518, 2009. ,
A Practical Guide to Splines, 1978. ,
Estimating mutual information using B-spline functions -an improved similarity measure for analysing gene expression data, BMC Bioinformatics, vol.5, issue.1, p.118, 2004. ,
DOI : 10.1186/1471-2105-5-118
Partition vs . comparison sidechannel distinguishers: An empirical evaluation of statistical tests for univariate side-channel attacks against two unprotected CMOS devices, LNCS, vol.5461, pp.253-267, 2008. ,
(The DPA contest, 2008. ,
ATmega 2561 Data Sheet) http ,
Exponentiation cryptosystems on the IBM PC, IBM Systems Journal, vol.29, issue.4, pp.29-526, 1990. ,
DOI : 10.1147/sj.294.0526
Multivariate Edgeworth-Based Entropy Estimation, 2005 IEEE Workshop on Machine Learning for Signal Processing, pp.311-316, 2005. ,
DOI : 10.1109/MLSP.2005.1532920
Nonparametric density estimation using wavelets, 1995. ,
Estimating mutual information, Physical Review E, vol.69, issue.6, p.66138, 2004. ,
DOI : 10.1103/PhysRevE.69.066138
