Abstract : This paper describes an elementary protocol to prove possession of anonymous credentials together with its implementation on smart cards. The protocol uses self-blindable attribute certificates represented as points on an elliptic curve (which are stored on the card). These certificates are verified on the reader-side via a bilinear pairing. Java Card smart cards offer only very limited access to the cryptographic coprocessor. It thus requires some ingenuity to get the protocol running with reasonable speed. We realise protocol runs with on-card computation times in the order of 1.5 seconds. It should be possible to further reduce this time with extended access to the cryptographic coprocessor.
Dieter Gollmann; Jean-Louis Lanet; Julien Iguchi-Cartigny. 9th IFIP WG 8.8/11.2 International Conference on Smart Card Research and Advanced Applications (CARDIS), Apr 2010, Passau, Germany. Springer, Lecture Notes in Computer Science, LNCS-6035, pp.209-222, 2010, Smart Card Research and Advanced Application. 〈10.1007/978-3-642-12510-2_15〉
https://hal.inria.fr/hal-01056105
Contributeur : Hal Ifip
Soumis le : jeudi 14 août 2014 - 18:26:47
Dernière modification le : jeudi 4 janvier 2018 - 18:34:02
Document(s) archivé(s) le : jeudi 27 novembre 2014 - 01:42:03
