Synthesis of Band-Limited Orthogonal Signals for Multichannel Data Transmission, Bell System Technical Journal, vol.45, issue.10, pp.1775-1796, 1966. ,
DOI : 10.1002/j.1538-7305.1966.tb02435.x
Data Transmission by Frequency-Division Multiplexing Using the Discrete Fourier Transform, IEEE Transactions on Communications, vol.19, issue.5, pp.628-634, 1971. ,
DOI : 10.1109/TCOM.1971.1090705
Principles of modulation and channel coding for digital broadcasting for mobile receivers, EBU Tech. Rev, vol.224, pp.168-190, 1987. ,
Peak-to-average power ratio and its reduction in wavelet-OFDM, International OFDM Workshop, pp.56-60, 2011. ,
PAPR analysis in wavelet packet modulation, 2008 3rd International Symposium on Communications, Control and Signal Processing, pp.799-803, 2008. ,
DOI : 10.1109/ISCCSP.2008.4537332
BER Comparison of DCT-based OFDM and FFT-based OFDM using BPSK modulation over AWGN and multipath Rayleigh fading channel, Int. J. Comput. Appl, vol.31, issue.10, pp.38-41, 2011. ,
Optimum FIR Transmitter and Receiver Filters for Data Transmission Over Band-Limited Channels, IEEE Transactions on Communications, vol.30, issue.8, pp.1909-1915, 1982. ,
DOI : 10.1109/TCOM.1982.1095661
Coded orthogonal frequency division multiplex, Proc. IEEE, vol.83, issue.6, pp.24-182, 1995. ,
Prototype filter and structure optimization, 2009. ,
Novel study on PAPRs reduction in wavelet-based multicarrier modulation systems, Digital Signal Processing, vol.17, issue.1, pp.272-279, 2007. ,
DOI : 10.1016/j.dsp.2006.08.002
Nonorthogonal pulseshapes for multicarrier communications in doubly dispersive channels. Selected Areas Commun, IEEE J, vol.16, issue.8, pp.1579-1589, 1998. ,
Spectrally agile multicarrier waveforms for opportunistic wireless access, IEEE Communications Magazine, vol.49, issue.6, pp.108-115, 2011. ,
DOI : 10.1109/MCOM.2011.5783994
Comparison of Orthogonal Transforms for OFDM Communication System, Electronics and Electrical Engineering, vol.111, issue.5, pp.77-80, 2011. ,
DOI : 10.5755/j01.eee.111.5.361
Closed-Form Approximations of the PAPR Distribution for Multi-Carrier Modulation Systems, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01054126
Variations on the projective central limit theorem, 2010. ,
Application de la théorie des bancs de filtres à l'analyse et à la conception de modulations multiporteuses orthogonales et biorthogonales, 2002. ,
Contribution à l'étude des modulations multiporteuses OFDM/OQAM et OFDM suréchantillonnées, 2007. ,
Hardware structure for Walsh-Hadamard transforms, Electron. Lett, vol.34, issue.21, pp.2005-2006, 1998. ,
PAPR Reduction of OFDM Signals by PTS With Grouping and Recursive Phase Weighting Methods, IEEE Transactions on Broadcasting, vol.57, issue.2, pp.299-306, 2011. ,
DOI : 10.1109/TBC.2011.2111210
Novel low-complexity SLM schemes for PAPR reduction in ofdm systems. Signal Process, IEEE Trans, vol.58, issue.5, pp.2916-2921, 2010. ,
Transformation des techniques " ajout de signal " en techniques " tone reservation, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00441468
BER performance analysis of OFDM system based on dual-tree complex wavelet transform in AWGN channel, 2009. ,
A PAPR upper bound of generalized waveforms for multi-carrier modulation systems, 2014 6th International Symposium on Communications, Control and Signal Processing (ISCCSP) ,
DOI : 10.1109/ISCCSP.2014.6877913
URL : https://hal.archives-ouvertes.fr/hal-01072519
