Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
DOI : 10.1137/0324047
Finite time stability of non linear systems, IEEE Conference on Decision and Control, pp.3641-3646, 2003. ,
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Etude de Quelques Problèmes de Stabilisation, 1993. ,
Lyapunov Functions and Stability in Control Theory, 2005. ,
Finite-time stability of homogeneous systems, Proceedings of the 1997 American Control Conference (Cat. No.97CH36041), pp.2513-2514, 1997. ,
DOI : 10.1109/ACC.1997.609245
Homogeneous coordinates and continuous asymptotically stabilizing feedback controls, of Differential Equations: Stability and Control, pp.249-260, 1991. ,
GEOMETRIC HOMOGENEITY AND STABILIZATION, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
DOI : 10.1016/B978-0-08-042371-5.50030-7
Finite time stability of homogeneous switched systems, 42nd IEEE International Conference on Decision and Control (IEEE Cat. No.03CH37475), pp.4271-4276, 2003. ,
DOI : 10.1109/CDC.2003.1271821
Continuous finite-time stabilization of the translational and rotational double integrators, IEEE Transactions on Automatic Control, vol.43, issue.5, pp.678-682, 1998. ,
DOI : 10.1109/9.668834
Higher-order sliding mode stabilization for a class of nonholonomic perturbed systems, Automatica, vol.39, issue.6, pp.1077-1083, 2003. ,
DOI : 10.1016/S0005-1098(03)00076-1
Finite-time stabilization and stabilizability of a class of controllable systems, Systems & Control Letters, vol.46, issue.4, pp.231-236, 2002. ,
DOI : 10.1016/S0167-6911(02)00119-6
Finite time stability and stabilization of a class of continuous systems, Journal of Mathematical Analysis and Applications, vol.323, issue.2, pp.1430-1443, 2006. ,
DOI : 10.1016/j.jmaa.2005.11.046
Non-Lipschitz continuous stabilizers for nonlinear systems with uncontrollable unstable linearization, Systems & Control Letters, vol.42, issue.3, pp.441-463, 2001. ,
DOI : 10.1016/S0167-6911(00)00089-X
Generalized weighted homogeneity and state dependent time scale for linear controllable systems, Proceedings of the 36th IEEE Conference on Decision and Control, pp.4342-4347, 1997. ,
DOI : 10.1109/CDC.1997.649536
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Semi-global finite-time observers for nonlinear systems, Automatica, vol.44, issue.12, pp.3152-3156, 2008. ,
DOI : 10.1016/j.automatica.2008.05.015
A Global High-Gain Finite-Time Observer, IEEE Transactions on Automatic Control, vol.55, issue.6, pp.1500-1506, 2010. ,
DOI : 10.1109/TAC.2010.2045698
URL : https://hal.archives-ouvertes.fr/hal-00455790
Finite-time consensus of second-order leaderfollowing multi-agent systems without velocity measurements, Physics Letters A, vol.377, pp.3-4, 2013. ,
On an output feedback finite-time stabilization problem, IEEE Transactions on Automatic Control, vol.46, issue.2, pp.305-309, 2001. ,
DOI : 10.1109/9.905699
Global Finite-Time Stabilization by Dynamic Output Feedback for a Class of Continuous Nonlinear Systems, IEEE Transactions on Automatic Control, vol.51, issue.5, pp.879-884, 2006. ,
DOI : 10.1109/TAC.2006.874991
Global output feedback stabilization of uppertriangular nonlinear systems using a homogeneous domination approach, International Journal of Robust and Nonlinear Control, vol.42, issue.3, pp.185-200, 2006. ,
State estimation and output feedback stabilization of a class of upper-triangular systems using a homogeneous observer, Proc. of American Control Conference, pp.4342-4347, 2010. ,
Optimal control : an introduction to the theory and its applications, 1966. ,
Singular optimal controls for second-order saturating systems, International Journal of Control, vol.86, issue.4, pp.549-564, 1979. ,
DOI : 10.1080/00207177308932413
Linear multivariable control : a geometric approach, 1985. ,
DOI : 10.1007/978-1-4684-0068-7
Finite Time Stabilization of a Perturbed Double Integrator???Part I: Continuous Sliding Mode-Based Output Feedback Synthesis, IEEE Transactions on Automatic Control, vol.56, issue.3, pp.614-618, 2011. ,
DOI : 10.1109/TAC.2010.2090708
H??? control, stabilization, and input???output stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.6, pp.819-829, 2001. ,
DOI : 10.1016/S0005-1098(01)00027-9
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
DOI : 10.1007/s00498-005-0151-x
ISS and iISS properties of homogeneous systems, Proc. of European Control Conference, p.2013 ,
URL : https://hal.archives-ouvertes.fr/hal-00801817
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, issue.12, pp.1159-1167, 2013. ,
DOI : 10.1016/j.sysconle.2013.09.004
URL : https://hal.archives-ouvertes.fr/hal-00877148
On homogeneity and its application in sliding mode control, Journal of the Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014. ,
DOI : 10.1016/j.jfranklin.2014.01.007
URL : https://hal.archives-ouvertes.fr/hal-00942326
Smooth stabilization implies coprime factorization, IEEE Transactions on Automatic Control, vol.34, issue.4, pp.435-443, 1989. ,
DOI : 10.1109/9.28018
Finite-Time Input-to-State Stability and Applications to Finite-Time Control Design, SIAM Journal on Control and Optimization, vol.48, issue.7, pp.4395-4418, 2010. ,
DOI : 10.1137/070712043
Universal stabilization of a class of nonlinear systems with homogeneous vector fields, Systems & Control Letters, vol.26, issue.3, pp.177-184, 1995. ,
DOI : 10.1016/0167-6911(95)00013-Y
