Stabilizing Dynamic Controller of Switched Linear Systems Analysis and Design of Hybrid Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2006
This paper is devoted to the problem of design a dynamic controller of switched linear systems. In the first part of this paper we give some remarks about the influences of switching signal on the asymptotic stability of switched systems. We give a practical example to generate a large class of switching signals. The second part is devoted to the switched dynamic controller design, based on a common lyapunov function approach. a sufficient conditions are formulated as an LMI problem for the switched controller design under arbitrary switching. A stabilizing switched controller with regional pole placements is also formulated as a convex problem, an LMI approach is used to derive the switched dynamic controller with performance limitations.
Fichier non déposé
hal-01056260 , version 1 (18-08-2014)
  • HAL Id : hal-01056260 , version 1
Salim Chaib, Abderraouf Benali, Driss Boutat, Jean-Pierre Barbot. Stabilizing Dynamic Controller of Switched Linear Systems Analysis and Design of Hybrid Systems. IFAC. Analysis and Design of Hybrid Systems, elsevier, pp.341-346, 2006. ⟨hal-01056260⟩
115 Consultations
0 Téléchargements
