Abstract : Peer-to-Peer networks are designed to provide decentralized, fault-tolerant alternatives to traditional client-server architectures. In previous work, the the resilience of structured P2P networks has been evaluated analytically as well as by simulation. In this paper, we discuss the influence of peer failures on a core component of our cost-optimized hierarchical P2P protocol Chordella. We show that the used algorithms lead to a working system even if a high number of superpeers is subject to failures.
https://hal.inria.fr/hal-01056490 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, August 20, 2014 - 10:06:07 AM Last modification on : Thursday, January 6, 2022 - 11:38:04 AM Long-term archiving on: : Thursday, November 27, 2014 - 11:11:47 AM
Quirin Hofstätter. Performance Impacts of Node Failures on a Chord-Based Hierarchical Peer-to-Peer Network. 16th EUNICE/IFIP WG 6.6 Workshop on Networked Services and Applications - Engineering, Control and Management (EUNICE), Jun 2010, Trondheim, Norway. pp.256-258, ⟨10.1007/978-3-642-13971-0_25⟩. ⟨hal-01056490⟩
